Electrical problem ABS ESP ??
Today, after work, I start engine, everything is OK, I reverse out from parking lot, change to D and... Lights come on... ABS, ESP and leveling system. I stop and start to read manual. I should be able to continue driving. I re-start engine but lights come on again. I drive few miles and I can feel that breake pedal feels totally different (softer). What have happend. After 5 minutes driving I stop again and re.start. Lights are off again and breakes feel normal.
WHAT HAPPENED?
Same issue or ... I can swear that turning signal could not keep rythm. First constant ticking and then few times rapidly and back to normal constant ticking ?? Can it be true or am I imagine??
Can anyone explain what have happened??
Thanks
good luck.
Robert Mariani
As for the rapid blinking, car is most likely telling you that one of your turn signal bulbs is out ot ready to go out. Turn on the turn signals or hazards while parked and take a look at all of the lights...front, rear and side markers.
All light came on. I re started it and it was OK.
I will take my car for recall monday. I will ask them to check it!
I will keep you informed!
What year & transmission do you have. Also do you have an Audi trailer hitch. This problem started for me after my hitch was installed. My thinking is maybe a wiring harness maybe loose and is causing electrical gremlins to appear.
I have an 03, with the 2.7T .
Thanks
