Left car for three weeks in below zero weather, returned to find rear suspension flat.
Old 01-04-2008, 02:26 PM
Senior Member
shadyraven's Avatar
Default Left car for three weeks in below zero weather, returned to find rear suspension flat.
When I started the car the little yellow air suspension icon came on in the dash and the compressor activated and filled up the rear suspension air bags. Both the right and left air bags appeared to have been down the same amount.
Old 01-04-2008, 02:37 PM
paulroad's Avatar
Watch it, but probably nothing..
Old 01-04-2008, 03:02 PM
AudiWorld Uber User
Bobby Kinstle's Avatar
Default That sometimes happens in very cold weather
the air volume decreases when it's cold and so the car goes down. Park it in a garage overnight and see if it sags at all to make sure you don't have any leaks.
Old 01-04-2008, 05:27 PM
Senior Member
shadyraven's Avatar
Will do. Temperature was around -15'C over the three week period it was parked.
Old 01-04-2008, 06:14 PM
AudiWorld Uber User
Default that's pretty damn cold
I parked mine on a sunny day in the 60's once and then came out at 15F at night and the car did the blinky light thing, but I didn't notice if it was low.
Old 01-05-2008, 04:19 PM
Senior Member
Sarge's Avatar
Default Definite possibility. Happened to me with tires driving from San Diego to Jackson Hole last month.
I was driving a friend's Subie Outback with fresh Blizzaks mounted , and noticed it was very squirrely once the roads got icy, like it wanted to fishtail all over, almost like it was constantly hydroplaning.
I immediately thought air pressure/flat tire, and sure enough once I pulled over and added about 14 PSI to the tires, all was well again.
The tires were mounted in San Diego at around 72ºF , and at the point I stopped it was about 3ºF. The tires were around 40PSI when I left (car fully loaded with gear, rocket box, etc). When I stopped they were around 28 PSI, which was under-inflated for the heavy load. I popped them up to 42 PSI and all was well again... mostly b/c of the temp change (increase in elevation factors in too).
Something to remember.
knepster
Q7 MK 1 Discussion
02-08-2022 11:56 PM
jeffkruse
11
01-26-2018 07:03 PM
abarmard
03-29-2014 07:19 AM
fca
04-27-2006 05:48 PM
ARmani
Audi allroad
01-22-2002 10:00 AM
Quick Reply: Left car for three weeks in below zero weather, returned to find rear suspension flat.
