engine coding
Old May 28, 2008 | 10:24 PM
Allroad_RS27's Avatar
Default engine coding
what engine code do you have
mine is 06752 isn't that for an A6 I think the allroad is - 06755 for northeast America?
from scan:
Address 01: Engine Labels: 078-907-551-AZA.LBL
Part No: 4Z7 907 551 M
Component: 2.7l V6/5VT G 0001
Coding: 06752
Shop #: WSC 02325
Old May 29, 2008 | 06:26 AM
Casey's Avatar
Default same coding as my ar.. depends on engine APB Vs. BEL
I have a very early 01 6 speed(Nov 00 purchase) APB engine, ECU is first of breed 4Z7 907 551 (no alpha designation)
Old May 29, 2008 | 06:53 AM
gragravar's Avatar
Default wow, no alpha designation? weird.
by my 03 it is all the way to a 551-S. IIRC, the BEL motors started somewhere around R
Old May 29, 2008 | 07:19 AM
y'allroad's Avatar
Default same ecu that i have - no alpha designation.
having had an a-box ecu in my s4, i was totally confused when i first discovered the lack of alpha designation. i wonder if the ecu was designed to be flashable to whatever alpha designation is needed. thoughts? j.
Old May 29, 2008 | 09:40 AM
allroad(s) lead 2Gavin's Avatar
Default My 2003 TIP has 07755...
Part No: 4Z7 907 551 S
Component: 2.7L V6/5VT G 0020
Coding: 07755
Shop #: WSC 65728
Old May 29, 2008 | 05:54 PM
Default Re: My 2003 TIP has 07755...
so you got the 5 in the end
it looks like most are 2s I wonder if there is any difference
you are west right?
Old May 29, 2008 | 07:26 PM
gragravar's Avatar
Default mine is coded 07715 for whatever thats worth
2.7L V6/5VT G02 0020
P/N: 4Z7 907 551 S
Coding: 07715, WSC: 65728
Old May 29, 2008 | 07:31 PM
I'm in Dallas, Texas...
Old Mar 27, 2012 | 02:57 PM
Kristopher's Avatar
grave digging
seems like a couple of you are coded to Sedan instead of Allroad, and others are 06 (TLEV) instead of 07 (LEV-more strict) yet none are in California.
My car is from CA. Now I have to go check my code and see. I was hoping to code to a lower emissions standard to avoid some of the EGT silliness...perhaps MX or SA?
http://wiki.ross-tech.com/wiki/index.../BES%29#Coding
2.7l T (AGB/AJK/APB/ARE/AZA/AZB/BEL/BES)
Coding
??xxx: Emissions
05 = Euro II/D3
06 = TLEV (USA)
07 = LEV (USA)
08 = GUS/China
10 = Euro III
11 = Euro IV/Japan
25 = South Africa
26 = Mexico/Taiwan
27 = Brasil
xx?xx: Powertrain
5 = Front-Wheel-Drive
6 = All-Wheel-Drive without ASR/ESP (with CAN-Bus)
7 = All-Wheel-Drive with ASR/ESP (with CAN-Bus)
8 = All-Wheel-Drive with Post-Switch Stage (Low Range - A6 Allroad only)
xxx?x: Transmission
1 = 6-Speed Manual Transmission
5 = 5-Speed Automatic Transmission (01V)
xxxx?: Vehicle
2 = Audi A6
5 = Audi A6 Allroad
The Ghost Rider
A4 (B7 Platform) Discussion
Aug 31, 2015 05:39 AM
mcfr171
Audi allroad
Jul 30, 2009 09:34 AM
spydervr4
3.2 24v VR6
Nov 14, 2008 04:46 AM
TecB5
VAG-COM Discussion
Sep 21, 2006 11:11 PM
calbaby
Jul 6, 2001 05:07 AM
