Engine overheats, no solution, advised to replace
What were the results of cylinder compression test and leak down test?
Where is the lost oil going? A dripping leak? Out the tail pipe? Into the coolant?
Oil leaks out around the engine, I believe from or adjacent to the turbos. Slight leak, which apparently is not uncommon in this car.
My question is whether overheating can become a chronic condition of an engine block with no apparent solution.
Second question would be what condition the viscous fan coupler is in, if it's not working well, you're going to have overheat issues under various driving conditions unless the weather is cold.
I would be curious as to what tests they have run, running flow tests seems to imply that they are aware of water pump impeller erosion issues and have ruled this out; I would assume thermostat has been ruled out as well.
Have they checked for combustion gases in the cooling system? And when it overheats, or when you think it is overheating, is it actually blowing coolant out the coolant reservoir cap's relief valve? How much coolant do you lose/have to add?
Assuming that the radiator is flowing well, the heater core is flowing well, etc, and you are absolutely positive that it is indeed overheating and not just reporting false overheat on the dash, then you need to check for combustion gases in the cooling system because blown head gaskets usually manifest in this way. Of course, maybe you have a small leak and are only blowing into the cooling system under high boost, but it doesn't take long for such a leak to get worse and blow combustion gas past the head gasket all the time.
Agreed that the oil leaks are likely unrelated, probably your cam tensioner/adjuster gasket leaking down to the turbos, very common.
