Ever had a flat?
Old Jan 22, 2004 | 09:26 AM
kierantaylor's Avatar
Default Ever had a flat?
Reading the manual last night about using the air compressor to inflate this mini tire and wondering if in practice its a PITA or trivial?
kieran
2001 AR 2.7t
Navigation/PDC
rubber AR mats
Old Jan 22, 2004 | 09:35 AM
paulroad's Avatar
Tech Guru
Default PITA? what is that?
Audi Roadside assistance is much easier than the spare inflation.
Old Jan 22, 2004 | 09:49 AM
glidar's Avatar
Default ain in the pass
<ul><li><a href="http://www.acronymfinder.com/af-query.asp?String=exact&amp;Acronym=PITA&amp;Find=F ind">http://www.acronymfinder.com/af-query.asp?String=exact&amp;Acronym=PITA&amp;Find=F ind</a</li></ul>
Old Jan 22, 2004 | 10:15 AM
paulroad's Avatar
Tech Guru
Default Ya know....
I fail to understand what Pacific International Trapshooting Association , has to do with an allroad...
Old Jan 22, 2004 | 10:17 AM
glidar's Avatar
Pull!
Old Jan 22, 2004 | 11:18 AM
markcincinnati's Avatar
That was a miskey It is PETA, Persons who Eat Tasty Animals!
Old Jan 22, 2004 | 11:40 AM
2tu®bos1mission's Avatar
pain in the ****
Old Jan 22, 2004 | 11:42 AM
Nalyd's Avatar
New Member
Default It's not that bad unless....
Your air compressor breaks like mine did. I used mine twice. The first time I had a flat tire and it worked fine. I used it a second time and it broke. I was reinflating my tires after deflating them to drive on the beach. I had to drive about 10 miles with 3 tires at 35 psi and the other at 17 psi.
Overall, the tire change kit is well designed. It's better then the knuckle scrapers I've used on other cars.
 Pouria Savadkouei
 Michael S. Palmer
Old Jan 22, 2004 | 11:53 AM
Default Thanks for the reply!
Is the air compressor meant for a few uses or was yours breaking an anomaly?
Old Jan 22, 2004 | 12:45 PM
ShowMeData's Avatar
Default Once - worked fine.
Chilled for 5 minutes in the parking lot while it inflated. The guys at Discount got a real kick out of the deflatable spare - pretty cool how it shrinks down when you let the air out.
