Front Sag
It does not happen everynight, is this a leak, or do these things just happen once in a while?
My solution for now is to restart the car 2-3 times. This seems to reset the sensor in the console and actually get the airspring raised. This is short term fix/workaround until I get the actual repair done - as soon as I get my extended warranty set up.
I've read on the forum that this situation can strain the air compressor (overworks?) so you have to be careful of delaying the real repair since it could cause other components to fail.
<img src="http://pictureposter.audiworld.com/56080/air-spring2.jpg">
At lower ride height: (leak)
<img src="http://pictureposter.audiworld.com/56080/air-spring3.jpg">
