Headlight Washers
Old Nov 25, 2003 | 02:54 AM
rdar's Avatar
Default Headlight Washers
Had our first cold snowy weather. Went to wash the headlights and nothing happened. Had this happen last year a few times also. Has anyone found anything to prevent the washers from freezing up? The book suggests using an antifreeze type chemical, but I am concerned about damage to the bumper.
Old Nov 25, 2003 | 05:02 AM
moto-one's Avatar
Default Is this the washer fluid freezing or the popup mec?
If its the fluid use a premixed fluid (Blue or Orange) I havent had a problem with it hurting the painte. If its the popup, You can lift them and spray some WD-40 or Ski binding silicone to keep them free.
Old Nov 25, 2003 | 11:43 AM
Rhoomba's Avatar
Default hmmm...
"an antifreeze type chemical"
um.. like alcohol?
(smile)
-Rhumble
01 allroad
98 VFR
Old Nov 25, 2003 | 12:42 PM
audir8rracer's Avatar
New Member
how do you wash the headlights anyway
Old Nov 25, 2003 | 02:15 PM
rdar's Avatar
Re: It's the pop up, sorry wasn't clear. Won't WD40 stain?
Old Nov 25, 2003 | 02:20 PM
rdar's Avatar
Default Re: I'm assuming it's something like the spray cantainers that can be used
to de-ice the windshield. I never like to use that stuff. Windshield wash is bad enough.
Old Nov 25, 2003 | 04:15 PM
ar2002's Avatar
Junior Member
Default I wouldn't use WD40 or Silicon; try low-temp white litheum grease,
WD-40 could be a problem with painted surfaces & plastic; silicone is typically not good below 40 F.
For the fluid, use a wintertime concentration of your favorite. I prefer the 20-10 brand.
Old Nov 25, 2003 | 04:25 PM
rdar's Avatar
Default Re: I usually use the better washer fluid. The blue stuff freezes too
easily. We spend most of our winter below freezing. The washers freeze up after the car is washed until there is at least some warm sun shinning on them. Last winter it seemed anytime I really needed them they were frozen.
 Pouria Savadkouei
 Michael S. Palmer
Old Nov 25, 2003 | 05:46 PM
MachineMan's Avatar
Default Re: how do you wash the headlights anyway
Pull wiper stalk towards you while headlights are on. The windshield washers start first and then the headlight washers kick in as well.
Old Nov 26, 2003 | 06:36 AM
moto-one's Avatar
Default Re: Compaired to the crap that they use on the roads around here wd 40 or silicon is mild
Just remembered that I have painted bumpers not he flat gray, ye I could see were that might stain. but I was thinking that if you lifted the spray cover and lubed the shaft that would help. And yes, when the front of the car is iced they wont pop up.
