Height adjustment
Height control is set to Automatic mode (the yellow manual light is off). Before getting on to the freeway, I set the car at the lowest height, but after running on freeway for a while, as soon as the car stop on a light, it will raise itself to the second height setting. Does this happen to your 2001 Allroad too?
According to AoA, they said its normal on 2001, for best handling and fuel consumption purpose! I though the car is best handle and fuel consumption when its at the lowest setting? Any help will be appreciated.
These are air springs, and they're actually a little firmer on setting 2 than 1 (think tall & thin with more pressure vs. short and squat with less pressure).
In the '01s, you can use the manual mode to defeat some of this automatic behavior, although it will lower itself out of 4 & 3 if you exceed the pre-set speeds. Also, that yellow light gets annoying. HPH
1 - boulevard/freeway cruisin' (and looking cool)
2 - Commuting/carving the turns
3 - More spirited city driving
4 - Who needs snowplows?
