Height adjustment ??
Old Oct 30, 2004 | 04:13 PM
NYBUILDER1's Avatar
New Member
Default Height adjustment ??
When my 05 allroad 4.2 height settings adjust on it's own, should the lights on the buttons change as well?
Old Oct 30, 2004 | 04:33 PM
BG AR's Avatar
Most certainly they should! Why, aren't they?
Old Oct 30, 2004 | 05:18 PM
mowog's Avatar
Default When I first got our 04 the auto level didn't seem to work- I found I had to position it in level 3-
and then it would auto level. If I manually drop it into 1 (lowest) on a smooth highway or to level 2 it won't go back up unless I hit the up button. At first I found the auto level annoying but now I am used to it and like it. I only drop to 1 on smooth highways as I mentioned or if loading dogs or stuff into the back. Try going all the way up to 4 (highest) and then see what happends- you should drop to 3 very soon, then 2 at 50mph, then back to 3 if you drop below 50 for awhile. Good Luck, Bob
Old Oct 31, 2004 | 10:58 PM
ReWa's Avatar
Default Yes and no
When the car is making minor adjustments(I mean it stays in the same level but needs to adjust because of e.g. added weigth)I don't see lights. When another level is set automatically because of speed then yes the lights (Up or down in the corresponding key and the level indicator) will light up / flash.
davidd86
Feb 28, 2005 06:40 AM
NYBUILDER1
Audi allroad
18
Nov 9, 2004 04:53 AM
HiTEC
9
Oct 20, 2004 09:50 AM
xalwafix
Sep 19, 2002 06:46 AM
