Help!
Old Jan 4, 2009 | 05:25 AM
sebas00's Avatar
Default Help!
I have two Questions:
1. I've changed the Camshaft seal, and the valve cover seal. But Oil still leaks. What else I Should look for that may cause this leak?
2. What is the Serpentine belt? is their a link to the actual product?
Thanks
Old Jan 4, 2009 | 05:39 AM
paulroad's Avatar
Tech Guru
the belt is what powers the alternator, A/C, etc.
Old Jan 4, 2009 | 06:31 AM
happy allroader's Avatar
Default Serpentine Belt
<center><img src="https://www.audiworld.com/tech/pics/eng63-19.jpg"></center><p>Serpentine belt is like what old cars used as a "fan" belt. On various cars it may run the water pump, air conditioner compressor, power steering pump, power brake pump, and alternator. They use to run a couple of these and you might find more than one belt usually in the shape of a V in a pulley. Now they tend to run one wide belt and instead of in a triangle over 3 pulleys they run a strange pattern so as to run all the pumps /devices.
Any place you normally get Audi auto parts from should have them.
Old Jan 4, 2009 | 11:11 AM
Bobby Kinstle's Avatar
AudiWorld Uber User
25 Year Member
Is it burning oil or dripping it?
Old Jan 4, 2009 | 05:21 PM
sebas00's Avatar
Default Re: Is it burning oil or dripping it?
it's both Burning and dripping.
Old Jan 4, 2009 | 05:22 PM
sebas00's Avatar
Default Re: Serpentine Belt
Thanks for the picture. now I know what to get. Thanks.
Old Jan 4, 2009 | 05:40 PM
kingfishgrapejam's Avatar
Default it may be your that the crank case ventilation system is clogged. I've only messed with the 2.8 on
this but do a search for spider valve or suction pump. It may help.
Old Jan 4, 2009 | 06:06 PM
girlroad's Avatar
Member
Default If your car is an early '01 model like mine you may have two valves instead of the
single suction pump of the later cars.
 Pouria Savadkouei
 Michael S. Palmer
Old Jan 5, 2009 | 02:17 AM
sebas00's Avatar
Default Re: If your car is an early '01 model like mine you may have two valves instead of the
Mine is an 02.
Old Jan 5, 2009 | 05:18 AM
girlroad's Avatar
Member
Default Then most likely you have the single suction pump...you can search for it here and
Carson at Riverside Audi can get you one...that will cause backpressure to build and you will blow oil all over the place if you don't fix it soon.
