help
Old Jun 11, 2012 | 07:28 AM
timmy1980's Avatar
Default help
i need help my 2001 allroad has main light on where the manual ride hight control is and the car will not lower the faster i go but i can manualy lower it the Code that shows us is P0065 can anyone tell me how to fix this.
Old Jun 11, 2012 | 07:38 AM
GTA_Driver's Avatar
Tech Guru
Did you try clearing the code? I don't think this one is related to your air suspension.
There is an option to disable auto-leveling, look it up and re-enable it if you want.
If you set the ae to level 3 then drive on the highway, does it drop to level 2 automatically?
Old Jun 11, 2012 | 09:46 AM
awdjunkies's Avatar
Hmm, Could that code be related to an emission component? Also, are you sure you aren't in "service mode" and that could be why it is not self-adjusting?
Old Jun 11, 2012 | 10:29 AM
PaperToast's Avatar
Banned
service mode disengages after you drive faster than 10-15 mph
it sounds like the manual mode is engaged; if so no worries.
just push the button for up or down and everything will be fine
Old Jun 11, 2012 | 11:07 AM
P4Ring's Avatar
Originally Posted by timmy1980
I need help with my 2001 allroad. The main light is on where the manual ride hight controls are and the car will not lower the faster I go, but I can manualy lower it. The code that showed up is P0065. Can anyone tell me how to fix this?
P0065 AUDI - Air Assisted Injector Control Range/Performance
Possible causes
- Air assist injector solenoid valve harness open or shorted
- Air assist injector solenoid valve poor electrical connection
- Faulty injector control relay
That code is not associated with the air suspension control.
Old Jun 20, 2012 | 06:05 AM
timmy1980's Avatar
P0065 how do i get it out of service mode or manual mode and if it is the problem y is the check eng light on?
Old Jun 20, 2012 | 09:40 AM
GTA_Driver's Avatar
Tech Guru
Get it to an Audi shop and fix your p0065 code.
a4_1.8t_01
May 22, 2009 06:18 PM
Meskeetdog
Dec 15, 2005 02:40 PM
dcblue
Jan 3, 2003 01:15 PM
got_root?
Nov 6, 2001 07:37 AM
got_root?
Nov 5, 2001 07:41 PM
