Help AR died while driving
Old Feb 16, 2014 | 03:14 PM
AudiARskiguy's Avatar
Default Help AR died while driving
While I was driving on the freeway today AR died (no power), had to coast to the off ramp and get towed - car had been running find, had just fill up tank, if I turn the key and all power stuff works fine and the car will turn over but without starting, it’s 6M ----- any idles?
Old Feb 17, 2014 | 02:13 PM
barny0055's Avatar
Fuel pump maybe first thought....Hard to tell..Any codes coming in vag com?
Old Feb 18, 2014 | 07:05 AM
Unfortunately I don’t have vag com, I do have a OBS II reader and P1142 was the code that pop up
Old Feb 18, 2014 | 07:30 AM
G0to60's Avatar
Not sure if it's related to the car dying but here's the explanation of the code. My vote is the fuel pump though.
http://wiki.ross-tech.com/wiki/index...0/P1142/004418
Old Feb 18, 2014 | 05:24 PM
PaperToast's Avatar
Banned
my guess is fuel pump or relay as well
whats the mileage of your ar?
Old Feb 22, 2014 | 06:24 PM
Zuffenhausen951's Avatar
1) fuel pump
2) crankshaft position sensor
3) coils
4) ICM
The fuel pump has NO diagnostic code it has failed in VAG-COM
Old Feb 23, 2014 | 08:21 AM
Prospeeder's Avatar
Fuel pump or Crankshaft sensor are the most likley. Coils...yes because all 6 failed at once....no. ICM, i dont think both could somehow fail all together and make 0 spark, there 2 and each one controls 3 cylnders. They will run as a 3 cylinder so.
Old Feb 23, 2014 | 07:06 PM
barny0055's Avatar
It may be helpful for you to get one of those cheap vag com cables and use the free software from Ross Tech. It will allow you to read the fault codes you have and clear them too.
Old Feb 24, 2014 | 05:55 AM
silverd2's Avatar
^^ Fully Agree ^^ ....If you don't have access to VagCom ($15 investment) and a service manual (Bentley), you don't have the proper tools to DIY...and just at the mercy of long distance guesses and/or a local clueless mechanic.
Old Feb 26, 2014 | 07:06 PM
RichH's Avatar
Had same problem; it was the fuel pump.
Vrrooom
Sep 8, 2015 03:06 PM
bilbo6209
10
Sep 4, 2015 04:07 PM
rammstien80
2.7T V6 Discussion
Sep 4, 2015 04:26 AM
A4QuattroV6
Sep 2, 2015 11:40 AM
