Help with engine codes
2 days ago I was accelerating out of a parking garage and heard a pop (like a hose coming off) and then the check engine light blinked on and off for about 5 secs then went OFF
Today I was driving up a steep bridge and accelerated - the check engine light came on and stayed on - below an output from the scan
Other than hoses (and Samcos are on order - we will take everything off and check next week) - did anything else break?
Also - installed a new SAI pump - but the sound its making is not the put-put-put it used to make. Can one or both of the valves it feeds into be clogged?
Thanks in Advance
Alex
Address 01: Engine Labels: 078-907-551-AZA.lbl
Part No: 4Z7 907 551 S
Component: 2.7L V6/5VT G 0010
Coding: 07755
Shop #: WSC 78646
WA1YD64B93N001011 AUZ7Z0B2141391
4 Faults Found:
17695 - Boost Pressure Control Valve (N249): Open Circuit
P1287 - 35-10 - - - Intermittent
17831 - Secondary Air Injection System; Bank 1: Insufficient Flow
P1423 - 35-00 - -
17819 - Secondary Air Injection System; Bank 2: Insufficient Flow
P1411 - 35-00 - -
17964 - Charge Pressure Control: Negative Deviation
P1556 - 35-10 - - - Intermittent
Readiness: 0000 0100
click on the 2.7t study guide and do a text search for the N249. you will see it.
http://allroadfaq.com/downloads/tech...ne_english.pdf
It controls the diverter valves, if its not opening (signal from ECU) the diverters won't move. Boost can build up and pop a hose, safe mode is possible etc. Follow the hose diagram on the PDF.
