Help - Level Control Fault Code
Old May 16, 2007 | 05:52 PM
PWDRSKR's Avatar
Club AutoUnion
Default Help - Level Control Fault Code
Ok, So I got my H-sports installed on my 2004allroad and had an alignment done for good measure. However while driving home my suspension warning light came on after several minutes of driving. When I got home I the ride on each wheel looked different from each other, so I got out a measuring tape. Sure enough all wheel ride heights were significantly different and according to my calculation all low.
S i decided to use the Vag and check things out. I figured that I would a "402" mod to correct each ride height. However, I got an error when the car tried level off at level two. Repeated attempts have also failed and now the warning light on the dash remains lit (previously it would go off if the car was turned off, but would come back on after a few minutes of driving.
So I ran a scan to check any DTCs. Sure enough I got this code:
Address 34: Level Control Labels: 4Z7-907-553.LBL
Part No: 4Z7 907 553 F
Component: - 2C1A1 D060
Coding: 25500
Shop #: WSC 42005
2 Faults Found:
01437 - Control Position not Learned
35-00 - -
01400 - Suspension Level Control
08-00 - Control Limit Surpassed
Anyone familiar with these and know if I can do anything (before heading to dealer)?
Old May 16, 2007 | 06:06 PM
Casey's Avatar
Default clear codes.. redo 402.. run car @ idle.. allow car to adjust (air springs/compressor)..
then while still parked cycle through all 4 settings. BTW.. did the installer put the suspension in "jack mode" before putting the car on the lift? Hope so....
Old May 16, 2007 | 06:10 PM
PWDRSKR's Avatar
Club AutoUnion
Default Re: clear codes.. redo 402.. run car @ idle.. allow car to adjust (air springs/compressor)..
Tried that. Didn't work. When I try to change ride height while car is running nothing happens. Car stays at level two...
Went to a german car specialist, so I would hope they used jack mode.
Old May 16, 2007 | 07:03 PM
Rally_nutcase_1982's Avatar
Senior Member
Default Drive at least 20MPH before you do the 402 again, then leave all settings as they are, don't
play with the numbers. Test each corner and let it return with 402 in the accepted field. Then apply channel 05 to ensure the module has learned it's position. This should eliminate the Dash light.
After that, measure each corner to see if the car is off. Remember, you must drive at least 20MPH again before another 402 attempt if your corner height is off and you want to change it.
Should all of this fail to get you back to normal then start attacking each ride height module, clean the contacts, make sure they are mounted properly etc pp. Usually the VAG will return with "value not accepted" if the ride height module is not in working order. The channel will determine the faulty corner/module.
Good luck and keep us posted.
Old May 16, 2007 | 07:04 PM
fastallroad's Avatar
New Member
If you find out that you need parts for your suspension, compare the prices for the individual parts or call me because I have an 02 allroad and I'm interested in removing the complete air suspension system for a cheap price. I currently drive my allroad everyday and everything works perfect, NO LEAKING AIRBAGS.I want to convert to standard suspension. If you are interested I will sell at a good price but for the complete system. My car is still under warranty, but I still want ti delete the air suspension. Contact me at 786-218-4277 , cramos0837@hotmail.com.
Charlie
Old May 16, 2007 | 07:18 PM
paulroad's Avatar
Tech Guru
Default so...did you lock the suspension
when the car was on the alignment rack?
If a warning light comes, and you notice the level is off..then the problem is not solved by releveling it.
What you saw was the symptom of another problem. In essence by trying the 402 adjust the car..you were clearing a symptom. Like clearing a CEL without finding the cause.
Leave the VAG alone and drive a bit. Get to level ground and LOCK the suspension with the buttons. If it will. Shut the car. Start the car, unlock and go to level 4..if it will.
No matter the outcome, get under and check each corner's level sensor unit. You probably have a wire that got cut or loosened during the Hsport install or more likely, the alignment.
Let us know.
Old May 16, 2007 | 08:28 PM
PWDRSKR's Avatar
Club AutoUnion
Default Re: Drive at least 20MPH before you do the 402 again, then leave all settings as they are, don't
OK tried that and when try do the adaptation procedure I get an error that says Channel 1 not available.
Old May 16, 2007 | 08:40 PM
PWDRSKR's Avatar
Club AutoUnion
Default Re: so...did you lock the suspension
ok, what do the sensors look like?
Old May 16, 2007 | 08:41 PM
Senior Member
Default Channel 1 is your front left corner, check the ride height module as mentioned before, ensure the
metal clip is properly mounted around the control arm and it's not lose.
If you are up for the challenge then simply disconnect the module and use a Volt/Ohm meter to ensure it works, this thing is nothing else but an inclosed resistor that changes resistance per position of the plastic arm.
Moving the arm up or down should show you different values on the Ohm meter, if the value doesn't change then it is well possible that you have a broken module.
If you are unsure about the method and the result, disconnect another one for confirmation. It's easy to do and not really rocket science, give it a try.
Old May 16, 2007 | 10:27 PM
allroadCole's Avatar
Default I had similar codes after not using jack mode. I had to replace a level sensor :(
same symptoms as you. Would not let me 402.
