Level Control Module?
4 Faults Found:
00774 - Level Control System Sensor; Left Rear (G76)
57-10 - Electric Circuit Failure - Intermittent
01771 - Control Module for Headlight Range (J431)
79-10 - Please Check Fault Codes - Intermittent
01780 - Sensor for Vehicle Leveling
04-10 - Mechanical Malfunction - Intermittent
65535 - Internal Control Module Memory Error
00-00 - -
I tried to clear the cods but the control module fault will not clear. can I unhook the battery for 24 hours or more to clear the module?
The suspension is still up but I am afraid not for long.
Is the level control module in the drivers side rear fender well? I looked in that compartment and I see something forward of the opening, is that it?
Thanks for any help. This is the only car I can drive because I am in a wheelchair and my wife's car does not have hand controls. I am getting worried that I am going to be stuck.
a fairly easy and not too expensive fix
replace those first and see if the other codes will go away
4 Faults Found:
00-00 - -
Here's a litte info on your last error. Search all of your error messages on the Ross Tech wiki
http://wiki.ross-tech.com/wiki/index.php/65535
Excuse me, just my question.
And the errors can not be cleared by "Clear Code-05" button. right?
