Is a little oil leak on the turbo return line OK? Isn't this a problem area?
Old Mar 9, 2006 | 07:00 AM
ArchAudi's Avatar
Old Mar 9, 2006 | 07:28 AM
Rally_nutcase_1982's Avatar
Senior Member
Default IMHO, every oil leak is a problem, and as closer to the turbo/exhaust as more dangerous it is
I wouldn't take any risk with that, if a few drops of oil catch on to the exhaust by chance - well, you know the possible outcome.
Also, what happens with your oil pressure when the leak is getting too big? How would it impact the engine/turbos?
I would have it fixed a.s.a.p.
Old Mar 9, 2006 | 08:13 AM
ArchAudi's Avatar
Default I have had it in for four consecutive repairs and now they REFUSE to fix it any further.
I don't know whether it's worth the time and trouble.
Old Mar 9, 2006 | 08:33 AM
paulroad's Avatar
Tech Guru
Default BTDT....as usuall..
A small oil return line or worse..oil feed line leak can't be ignored by anyone..including the dealer. Change dealers if they can't help what is obviouse.
If the oil lines feeding the turbos are leaking and they get worse.. guess what part would be indanger of running without enough oil..under high heat no less.
If the return oil lines leak worse..it is also a problem but more mess than danger..unless you run the car dry.
I had a little one that went big time and alsmost starved the entire engine of oil.
The oil is pressureized as it feed through the turbos that is why they leak. The seals.. wear and the get worse and then all of a sudden..<ul><li><a href="https://forums.audiworld.com/allroad/msgs/105301.phtml">the oil hits the ground...</a></li></ul>
Old Mar 9, 2006 | 10:08 AM
grey-2002-ar-6sp's Avatar
Great letter to Anchor! Was their response satisfactory?
Old Mar 9, 2006 | 10:25 AM
paulroad's Avatar
Tech Guru
Default Totally fine...I now have 92K without incident.
The point is that little leaks must be tended to because the become big and expensive.
Old Jun 1, 2015 | 06:44 PM
penogg's Avatar
Default Right oil Return Line
I just replaced the right oil return line gasket and STILL seems to have a leak..Anyone know why?? And what's next?
P
Old Jun 4, 2015 | 04:34 AM
PetrolBear's Avatar
Why did you change that hose?
- It can be a sealant problem (or improper mount?).
- Or you have an extra pressure there because of clogged oil pan ventilation system - but in that case you gradually would have more leaks from everywhere.
Old Jun 4, 2015 | 06:30 AM
penogg's Avatar
I haven't changed the hose, just the gasket (now twice) and the leak continues.
I'm hoping that I don't have to change the hose at $180!
Old May 13, 2021 | 02:26 PM
anilc23's Avatar
Sorry for restarting an old thread but did you find out why it was still leaking? I'm having this problem at the moment... Changed gasket twice
Was going to just put some silicon on it before I came across this thread
stigg
Audi allroad
14
Jul 10, 2014 06:14 PM
mendelo
Audi allroad
Oct 16, 2012 05:27 PM
limbertjh
May 4, 2011 07:16 PM
woodrock
Aug 20, 2007 11:22 AM
nadrealista
Dec 20, 2005 11:27 AM
