Is this normal?
Old Sep 7, 2003 | 09:02 AM
makiedog's Avatar
Default Is this normal?
When I'm done driving, turned off the ignition and stepped out of the car, I hear short busts of air bleeding out of the suspension system. I don't see any noticible change in vehicle height. Is this normal? If so, why? Thanks.
Old Sep 7, 2003 | 09:31 AM
srs's Avatar
srs
Default Yes. It readjusts to the correct height
(for the specified level) after weight is removed - even after the car is turned off. Of course, if it needs to run the compressor to raise the suspension to get to the specified level, it won't do it until you turn the key on again, but it does release air after the car is off. I particularly notice it after unloading heavy stuff from the back when the car is off.
Old Sep 7, 2003 | 04:06 PM
JimiRayClapton's Avatar
Default Is it normal to go to the lowest level with ride-height indicator flashing?
I've had that happen from time to time.
Old Sep 7, 2003 | 08:13 PM
srs's Avatar
srs
Default I've never had it do that.
Sometimes it readjusts after a stop, but the indicator doesn't flash then.
Faaz.Baig
May 16, 2019 07:35 PM
smulder
Jan 7, 2017 08:04 AM
mrandrewjames
Oct 31, 2016 03:11 PM
parkinman
Audi allroad
24
Oct 4, 2010 12:06 AM
Moab
Audi allroad
10
Sep 30, 2007 05:57 PM
