Offset question...
Old Mar 12, 2009 | 08:58 AM
mlw911's Avatar
Default Offset question...
Looking at buying a set of OE S4 rims. They come with a 45mm offset. First off is that going to require too large a spacer for safety/performance purposes and secondly any idea on size lugs I would need? Even better a link to the type of H&R spacers would be awesome.
Thanks
Old Mar 12, 2009 | 09:02 AM
paulroad's Avatar
Tech Guru
Default you would need a 20MM spacer and new lug bolts...
I'm not a fan of that thick a spacer.
I have wheels that use a 10MM and they ride great, I have wheels with a 20MM spacer and I find that they accentuate every vibration.
I spoke to my audi guru/tech (tyrol sport in queens, ny) and he always suggests no spacer on his client's cars. The added vibes that you feel are also added geometric forces that the components are being hit with. Especially the main wheel/rotor/bearing assemblies.
But there are opinions on both sides of this.
Old Mar 12, 2009 | 09:23 AM
mlw911's Avatar
Default Re: you would need a 20MM spacer and new lug bolts...
Thanks Paul. Spoke to the guys at Achtung and they suggested going with the DRA adapters and then bolting the wheels using my existing studs to those - but you do have a point. 25mm spacers seem like a lot.
Old Mar 12, 2009 | 05:08 PM
QCRAZY's Avatar
Spacer width doesn't matter. Any spacer should be hubcentric. Once bolted it will have similar geometery/forces as the factory wheel.
Old Mar 12, 2009 | 06:23 PM
paulroad's Avatar
Tech Guru
Default Q.. I dont' think so.. simple lever and fulcrum...
the further out from the center point you are, etc.
Old Mar 13, 2009 | 04:54 PM
QCRAZY's Avatar
Default Where's the lever and the fulcrum??
By the definition of offset, the geometery of the wheels have to "match". As long as the spacers are hubcentric there is no lever; at least no different then what the factory wheel would have.
In fact, the lever would be the same with a non-hubcentric spacer; you just get other forces at play with those.
ddrieger
Mar 20, 2007 10:18 PM
Silver Express
Jun 30, 2006 08:06 PM
esanmiguel
Jan 24, 2006 05:11 PM
Dahousemon
Aug 10, 2004 01:05 PM
