Re: Plastic wrapper
In regards to my concerns they realigned the door, 1/2 hr job, and they are replacing the windshied with a new one from Audi (ordered). As for the car that you are looking at, what is the milage on the vehicle and did it come from another dealer. If the flat happend while it was on its way to the dealer was it on a trailer or being driven? Have them replace the tire and if you cannot be there when it is done use a marker and mark the flat (without them looking just to see if they are willing to work with you and not save a couple of bucks on fixing the flat). If it was being driven I would try to inspect the rim once the tire is off for any damage. Ask them to do any alignment as well. I would probably have them put the vehicle on a lift and inspect the suspension undercarage as well. If it came form the port and not another dealer it should still have the plastic on it. If this is all to much to take just hve them get you another vehicle. When I went to get an allroad - the car was more important to me than the options, so I gave them 2 colors to chose from and said it had to have conv and prem pkgs, they found the car that day. Hope all this helps, good luck you'll love it once you get it.
