Problem with heating
Old Dec 1, 2017 | 07:28 AM
Honda65's Avatar
Default Problem with heating
i have a Audi a6 allroad 2,5tdi 2003 and i have change vaterpump and termostat and flush register but the air inside is not bring warm. The temp. on the car is betwin 80-90 degrees. Someone ho has a good idea for what is wrong?
Old Dec 1, 2017 | 08:11 AM
amiram's Avatar
You need to drain air from the car's cooling system
Old Dec 1, 2017 | 08:18 AM
Honda65's Avatar
yes I have Done that to
Old Dec 1, 2017 | 02:22 PM
PaperToast's Avatar
Banned
heater core could be plugged
flush it and see if that helps
Old Dec 2, 2017 | 10:50 PM
Honda65's Avatar
Im not so very good to do things with cars and im not sure where i Could find this? Can you tell me where it is in the car?
thanks
Old Dec 3, 2017 | 10:21 PM
amiram's Avatar
In the left picture you can see the upper pipe (with the air drainage hole ) of the heater core and below it the second pipe . Disassemble both of them and insert water pressure once from the upper pipe ( aluminum ) and once from the lower
Old Dec 4, 2017 | 09:32 AM
PaperToast's Avatar
Banned
this is for the US version of the allroad, but the procedure should be the same
quattroworld.com Forums: Heater Core Flush - 2002 allroad 2.7t
zenmaster2007
Nov 29, 2006 04:14 AM
gregp1962
Dec 1, 2005 01:59 PM
TopFuelWeimar
Audi 100 / A6 (C4 Platform)
Apr 9, 2004 09:06 AM
phat bob
Feb 26, 2004 05:42 PM
Muhammad
14
Apr 18, 2002 01:22 PM
