Setting Allroad Computer
Old Nov 5, 2004 | 03:29 PM
beantownallroader's Avatar
New Member
Default Setting Allroad Computer
I just got my 01 Allroad back from its 30k service. The computer display was different when I got it back, and I am not able to toggle through the different options. The only setting I can get on is one that says MPH with a jagged circle around it. An, alarm similiar to the reserve gas alarm also comes on and off. Any thoughts of how to reset this>
Old Nov 5, 2004 | 03:47 PM
BonanzaMan's Avatar
Take it back to dealer and tell them to fix it
Old Nov 5, 2004 | 03:54 PM
paulroad's Avatar
Tech Guru
Default This is your mph warning.
On your dash is a push in reset button. 1 is for the trip/odometer the other will set the MPH buzzer. While not moving the car, push and hold the button. The Slash mark will clear and you willhave normal menue control.
Old Nov 5, 2004 | 04:12 PM
ksquared71's Avatar
Mine is on the windshield wiper control...on the end you can go up or down to scroll through options
Old Nov 5, 2004 | 07:02 PM
banditoamigo's Avatar
Default Do you have the "computer" switch by the armrest?
If you do, you can turn on and off individual functions using the dial. I had the same problem w/ mine when I bought it (knew it could do more than just miles to empty b/c my wife has an A6) -- you just need to go to the "computer" settings to turn each function on or off.
Wasn't immediately obvious after RTFM, but after some tinkering you'll figure it out (if that's the problem). As K2 said, you toggle through with the wiper lever, but the armrest (in front of hand brake actually) switch is what turns it on and off. Good luck.
king23james05
A4 (B7 Platform) Discussion
Jun 25, 2019 07:52 PM
sgriffiths
Canadian Discussion
Nov 25, 2010 06:50 PM
ashim
Aug 26, 2004 11:59 AM
ZLP-RVOVOM
Feb 15, 2002 12:24 PM
BDW
May 15, 1999 07:25 PM
