Squeaking door
Old Mar 6, 2012 | 03:41 PM
jay_cat's Avatar
Default Squeaking door
My drivers door squeaks when I open it and I can't figure out were to lube. I sprayed the hindes with lithium grease and it still squeaks. I had it at the dealer yesterday and the tech tried also. Anyone else have this issue or a solution?
Old Mar 6, 2012 | 06:37 PM
ezveedub's Avatar
It's probably the lower door check spring. At the bottom hinge, there is set of cam rollers that rock against a metal "S" shaped spring wire that holds the door at different positions. They usually squeak there (see if they are rusty looking). If so, I've used anti-seize paste brushed on the rollers with a small brush where the spring rides the rollers and it usually stops making noise. I usually spray the hinge pivots with Wurth HHS2000 spray grease or Winzer Polylube grease.
Old Mar 7, 2012 | 02:22 PM
jay_cat's Avatar
I never thought of using a brush to work the greese were the spray doesn't hit. Thanks for the tip.
wishyy1
New Member Welcome Area
Jan 9, 2018 10:05 AM
4corners
Apr 30, 2006 05:36 PM
autibahn
Apr 20, 2005 04:44 PM
Laughing Gnome
Jun 7, 2004 05:55 AM
Doug K
Jan 8, 2002 07:02 AM
