Squirter help needed..
Thanks for any guidance.
Removing
- Remove bumper.
- Disconnect washer fluid connection of headlight cleaning system -X-.
- Disconnect connection between spray jets to washer fluid line.
- Pull spray jet covers upward at bumper and unlatch retainers using a small screwdriver.
- To remove spray jets -1-, remove both screws -2- in each case.
- Loosen Phillips screw -4- at spray jet retainer -3-.
Installing
Installation is reverse of removal, noting the following:
- Secure spray jets -1- by threading in the two mounting screws -2- at bumper.
- Thread in Phillips screw -4- at spray jet retainer -3-.
- Set cover for spray jets in place and engage audibly.
- Connect washer fluid line to spray jets.
- Connect washer fluid connection of headlight cleaning system -X-.
- Install bumper.
