Stuck in neutral
Next, I can feel and hear a switch engage under the shift lever that is trying to do its job, but I'm not sure that is the problem.
The little foot/brake light next to the shift lever does not come on when I press on the brake.
Also, I have no adjustable suspension. The control buttons on the dash don't even light up and I the suspension warning light on the instrument cluster has been on for several months and now that has gone away. I'm also getting an oil sensor warning symbol on my instrument cluster readout.
Are these all separate gremlins that I am chasing or is there a common denominator?
If you have no green lights by the up/down buttons, you've probably blown the suspension control module.
The warning in the instrument cluster may have disappeared because of a failed fuse. Check Fuse #5, a 10-amp fuse that's the most-left in the second row from the top in the panel at the end of the dash on the driver side:
<img src="http://www.pbase.com/kneale_brownson/image/150484424.jpg">
If that's OK, check the big 40-amp fuse and adjacent relay in the last row (closest to the floor mat) under the knee bolster below the steering wheel, called the 8-fold panel. It's a real PITA to get to, requiring a bunch of disassembly. See the description in the Bentley. If the relay and fuse are OK, you'll need a new suspension control module.
Do you know if there is a write up or video on how to get to that 40 amp fuse?
EDIT: The compressor did make a lot of noise and I knew it was time for a rebuild.
Also, would this have anything to do with why the shift lever won't work?
Checking the 40 amp involves removing the trim above the wheel (pull up and out) then remove four screws.
Link to a picture of the module:
IMAG0487 | Flickr - Photo Sharing!
I don't know what the testing procedure would be.
