Stutter, hesitation during warmup 2.7 TIP
Old 11-14-2018, 11:07 AM
Carbunkle's Avatar
Default Stutter, hesitation during warmup 2.7 TIP
SOLVED! Cold start, drive 40 seconds and get stutter like ignition on all cylinders is clicking off and on fast. Until this morning it would clear after one short 10 second session of this. I drove all day for weeks like this, only happened cold. 19 degrees this morning it stuttered and and all dash lights popped on, engine dropped to idle, gas pedal has no effect, crept home 2 blocks at idle. never came back on. Idles fine with no stutter and leaves no trace on OBD11 log! The EPC, TC, and Air Suspension lights turned on. The engine light is always on (preheat for the O2). I'm thinking crankshaft position sensor if it has one. Gas pedal has no effect - I think this is key. Any help would be greatly appreciated.
Also - Anyone in southeast Michigan have VAG/COM to run on this? If I let it warm up I could probably meet anywhere.
2001 Audi allroad 2.7 TIP 198K
Old 11-16-2018, 12:58 AM
PetrolBear's Avatar
Have you checked (download!) SSP198? There are some good info about the throttle pedal features.
BTW, mine started also to stutter in cold, and some weak misfires as warm (as it would run on 5.5 cylinders or so) but not always. Symtom should be: corroded / old power cables to injectors and ignition. We will renew them completely up to the ECU. Prior I replaced the last 20-30cm of ignition cables and contacts between the cylinder heads, in line with TFSI upgrade ~ 2 years and 22k miles ago. Mine has also 192k miles (at least)
Old 11-16-2018, 10:19 AM
Carbunkle's Avatar
Thanks, I'll look into all those possibilities. Thanks
Old 11-19-2018, 06:05 AM
Carbunkle's Avatar
Replaced gas pedal assembly with sensor. $10 from an A6 3.0 donor. Thanks for the Self Study info. That's what cracked the code.
Old 11-25-2018, 11:36 PM
PetrolBear's Avatar
Great, my pleasure!
The 10 USD part solved the mystery.
bpp
A4 (B8 Platform) Discussion
04-17-2014 09:46 AM
highmiles
10-28-2012 08:39 PM
amall99
11-21-2011 03:45 PM
Sarge
08-07-2003 11:08 AM
Mike
12-15-1999 02:04 PM
Quick Reply: Stutter, hesitation during warmup 2.7 TIP
