suspension fault code
Old Jan 24, 2008 | 06:12 PM
QuattroxSA's Avatar
New Member
Default suspension fault code
hi guys! can anyone help me with the following fault code?
01400 suspension level control
11-10 control limit not reached. intermittent
the suspension stays in the lowest setting and when its trying to raise the warning light comes and stys on.
what is the problem and where do i find the faulty sensor on the car?
thanks in advance.
Old Jan 24, 2008 | 08:09 PM
Bobby Kinstle's Avatar
AudiWorld Uber User
25 Year Member
Default It would tell you if it was a bad sensor
I haven't seen that code, and I've seen quite a lot of codes.
Old Jun 13, 2008 | 05:20 AM
mcbk1452's Avatar
New Member
Default Re: suspension fault code
Yeah, I got that same code after I replaced the stupid front level sensor (G78).
I had this code before:
Address 55 -------------------------------------------------------
Controller: 4Z7 907 357
Component: dynamische LWR D07
Coding: 00030
Shop #: WSC 02325
1 Fault Found:
00776 - Level Control System Sensor: Left Front (G78)
31-10 - Open or Short to Ground - Intermittent
Then the car was fine for about a week then other suspension fault codes popped up. Most of then were cleared out. I did a 402 mod to "level"things out. It worked for a week then finally, last night the above code came on about the suspension level control:
I'm waiting for my Bentley shop manual to come in so I can figure this out. Tom Butler (member of this forum) has been very helpful so far and he's taken care to copy a few troubleshooting tips from the Bentley manual.
Anyways, let me how you it goes with you.
jeffkruse
15
Jul 25, 2016 08:57 AM
Will Perdue
16
Apr 28, 2014 03:06 AM
CtrlAltDel
VAG-COM Discussion
Aug 4, 2013 02:35 PM
310ALLROADER
VAG-COM Discussion
Jun 29, 2007 09:30 AM
