TPMS Code.
Friday,27,June,2014,17:34:40:24162
VCDS Version: Release 12.12.2
Ellis Auto Tech
Address 65: Tire Pressure Labels: 4D0-907-273.lbl
Control Module Part Number: 4D0 907 273 A
Component and/or Version: Reifendruckueberw. D210
Software Coding: 22307
Work Shop Code: WSC 23352
VCID: 255F3C08BFBF6436C81-515A
Fault Codes have been Erased
1 Fault Found:
01487 - System Function Test
67-00 - Set-Point Not Reached
I also have a light symbol on the driver info screen that is not noted in the owners manual. It is a yellow tire cross section with a line through it and an exclamation point in the middle. I have attempted to reset the pressures from the menu as well. It goes through the "checking" phase but no confirmation on anything.
I have turned it off in VAG-COM but it comes right back. One of my wheel does not seem to have a TPMS transmitter in it.
Was not a problem until I pulled a few fuses.
Any ideas?
I am new to the AllRoad so I can't help just yet. But this guy its awesome and normally gets back asap. He also has a youtube channel that he shares most his work with Audi's and VW's.
exovcds.freeforums.org ? Index page
https://www.youtube.com/channel/UCm3...A-Z1P436Fkjfxw
Hope he can help you.
