Trunk switch problem!
Old Aug 8, 2006 | 03:47 AM
bmwrt's Avatar
Default Trunk switch problem!
5 out of 10 times that I get out of my car, my legs hits the trunk switch by the door and unlocks the trunk. Does anyone else has this problem? Any suggestions in what should I do?
Thanks
Alex
Old Aug 8, 2006 | 04:33 AM
happy allroader's Avatar
Never heard of this problem. Suggestion: be more careful getting out of the car? (sorry)
Old Aug 8, 2006 | 06:07 AM
paulroad's Avatar
Tech Guru
short of cutting off your leg?. what if you move your seat back before you get out?
Old Aug 8, 2006 | 06:39 AM
ShowMeData's Avatar
Default right forum? I don't see how that's possible on my ar.
The trunk release switch (which I've pressed even once) is on the front of the B-pillar.
Old Aug 8, 2006 | 06:43 AM
Woodman-ar 01's Avatar
Member
2nd. How do you swing your legs that far to the left?
Old Aug 8, 2006 | 06:51 AM
gragravar's Avatar
Default the switch on the B pillar? never been an issue I don't swing around that far. Also, your sig pic-
Is that the Erie (CO) airpark in the background? just curious, kind of looks like it.
Old Aug 8, 2006 | 07:26 AM
blackIIIroad's Avatar
Default Perhaps you have the after market toggle switch instead of the normal button....
and yes! anyone would hit this on the way out? Only way for this to happen is with the seat all the way back (you're tall) & swinging your leg into the button. This would also take a bit of skill to push your leg into the recessed button for half a second just to get this to work!
Old Aug 8, 2006 | 12:39 PM
bmwrt's Avatar
Re: no. Its Honolulu Airport. Sorry but I don't know how to change my sign pic.
 Michael S. Palmer
Old Aug 8, 2006 | 12:42 PM
bmwrt's Avatar
Default Re: Correct. So when I swing to get out of the car, my leg hit the switch
I do use my seat on the very extended position. I do have long legs.
Old Aug 8, 2006 | 12:51 PM
bmwrt's Avatar
Re: i don't think I do have an aftermarket switch!
