Wastegate Control Lines
Cycled the N75 with the VAG-COM (click...click...click). Pulled the N75 and blew through the pressure supply (bottom) port and air came out the correct side (boost pressure to open wastegates).
Compressed air to check wastegate operation (figuring I'd hear them actuate with 10 psi) and "whoosh" from a leak but, for the life of me, I cannot see the leak.
Going to check sides tomorrow (got dark outside and had to put kids to sleep).
Big question is - To replace/repair the lines how much disassembling as I'm looking at? I've had this beast about a month and can't even see the turbos. Have the lower skid plates removed and most covers. I'd be happy if someone told me how to even see the wastegate servos.
Any help appreciated.
The best is if you ever have to replace a turbo. This requires a partial to full removal of engine.
Audi wasn't thinking of ease of maintenance when they designed the 2.7t engine bay.
I did see the turbo when the sun came out but it's way up in there and I only saw the actuator arm, not the servo.
Pulled loads of crap out of the way from the engine compartment but, alas, that didn't get me anywhere.
Going to pull the wheel and inner fender liner next to see if that gets me any closer.
Probably going to fabricate my own line to replace/bypass the original as I can't see over $100 for a low pressure line. Must have some stainless tubing laying around somewhere.
Getting ahead of myself - have to actually get a hose connected to the wastegate servo first before I can think of bypass.
Fortunately it is only 90F+ and about 80% humidity out right now.
Onwards and upwards.
What I wouldn't do for a mechanics endoscope.
It is just way to tight in there to get to "nipple" on actuator let alone get clamp off/ on.
At least I sighted the thing.
Is it possible to do the same thing in the newer turbocharged Audi vehicles?
This exercise has taught me a lot about the way charge pressure is controlled by the stock ECU.
You could chip the vehicle but then you would need to beef up the intake to deal with the increased boost. Noticed that most of the problems (broken components, etc.) are the result of trying to wring more power out of the engine than it was designed for.
I'm not looking for uber-performance, just want the stock to work correctly. The current state results in power comparable to a Subaru.
run your boost line to right after the throttle body evap line.
2500 psi at the throttle body on a stock setup.
i today did a hitachi to bosch conversion, what a waste, damm bosch reads 25 g/s at 800 rpm, and if i punch it it goes over 400 g/s second at 1800 mbar. i even rigged the hitachi into the bosch housing, even worst and it drove like poo.
but i did find after using a ultimeter to the dbw housing that pin 6 controls load for the whole car.
does anybody know which one is for throttle cut???
i guess i will just snip 1 by 1 untill found.
However, this is about fixing the wastegate control line and I'm elbows into it. Front lock carrier is off and I can see the damn line now. Too late to pressurize and see if that is where the leak actually is.
Fortunately, I bought this thing used and, being cautious, am replacing the timing belt/water pump/tensioners so the lock carrier had to come off anyway (just passed 100K miles). Kit will arrive tomorrow.
Unforseen issue - DIY writeups and Bentley failed to mention transmission cooler line removal. Again, I already had a new transmission filter on hand. Too bad it appears to be a PITA to fill the system properly.
Tomorrow will start working to get the motor mount bracket off so I can actually access the actuator and put on home made line. Too bad the local auto parts stores are light when it comes to braided silicone line. Think I'll just route the line such that it won't experience the heat from the exhaust and, if I ever have to completely pull the engine, I'll fabricate SS lines myself.
