What the deuce is this warning light
Old Jan 27, 2016 | 06:06 PM
ToolmanAR's Avatar
Default What the deuce is this warning light
My turn signals stopped working today, which I assume is a faulty blinker relay, but I also got this warning light on the dash. Oddly enough, there's zero mention of it in the manual--just a blank spot where this light is and no indication that there's anything there.
I presume it's related to the turn signals, but what is it telling me?
Old Jan 27, 2016 | 10:35 PM
amiram's Avatar
[QUOTE=ToolmanAR;24770382]My turn signals stopped working today, which I assume is a faulty blinker relay, but I also got this warning light on the dash. Oddly enough, there's zero mention of it in the manual--just a blank spot where this light is and no indication that there's anything there.
I presume it's related to the turn signals, but what is iIn
In the owner manual this light says "Trailer turn signals"
File Type: pdf
Old Jan 28, 2016 | 06:25 AM
G0to60's Avatar
Yep, this comes on when you have a trailer hooked up and the turn signal is on. Sometimes it comes on with a faulty or aftermarket turn signal/hazard light relay.
Old Jul 23, 2021 | 01:23 AM
HannahParsons's Avatar
I had it, do not worry, it's nothing, it will burn a little and will stop. I only had severe problems with the air conditioning in my car. I had a damaged refrigerant: The refrigerant plays a critical role in cooling the room. But sometimes, due to manufacturing defects, the refrigerant level can be below. There is also the possibility of a fixed refrigerant leak inside the air conditioner. It is advisable to call a professional to check it before the problem becomes more serious. I've learned that No matter what the problem is, trusting https://www.marvellous.sg/aircon-chemical-wash/ is the right way to go.
Old Jul 23, 2021 | 03:51 AM
smil3y's Avatar
maybe a short or bad contact in the relay? I never had that light before until my OEM relay died and the turns stopped flashing (would just go solid on when I moved the stick). I replaced it with one of these:
https://www.partsgeek.com/gbproducts...-02861662.html
and now your light blinks on my dash when my turn indicators blink (but the signal lights are working again!)
ericcorp
Audi allroad
Jan 12, 2016 12:24 PM
a4tisâ„¢[Bye Turbo]
9
Oct 23, 2005 04:09 PM
SoTeriK1
May 26, 2005 10:08 PM
LexusPete
Jan 11, 2005 08:11 PM
bobos
Feb 13, 2003 04:33 AM
