why is PRNDS lit up?
Old Mar 9, 2014 | 10:36 AM
KDL's Avatar
KDL
Default why is PRNDS lit up?
I have been having battery problems, and recently my mechanic charged the battery up and said it should be OK but keep an eye on it. This morning I started the car up, but it sounded for a second like it wouldn't start, and then PRNDS lit up on the screen. I could not engage tiptronic -- nothing on the dash, no change in transmission -- and the car needed a heavy foot on the gas to make it move off the line, i.e. lots of revs, not much action. After driving around for a while, I shut the car off, turned it on again, and all seemed fine, maybe because the battery was charged up. Any theories or insights on what this is about would be much appreciated. Battery is less than a year old, btw. Thanks as always.
Old Mar 16, 2014 | 08:03 AM
chasndebs's Avatar
Hi, I have been having similar problems. Tiptronic went into limp mode (PRNDS) all lit and car in third gear. If the car is stopped and switched off, then switched on again it operates normally for a while: two or three miles or sometimes 40-50. Data logger shows error code 17100: 'input speed sensor range/performance' whatever that may mean. Trawled the net; all sorts of possible causes - sensor failing, loose connection etc. Will take it gearbox specialist next week and brace myself for cost of repair. Will post again when I discover cause(s).
Old Apr 10, 2014 | 12:33 AM
chasndebs's Avatar
Since last I posted I have had the PRNDS fault diagnosed and it is a faulty sensor which is being changed as I write this. When I took it to the shop for repair it was a journey of > 100 miles and it did not slip into limp mode at all during the journey. As a matter of interest one of the hydraulic engine mountings has failed and exhibits a permanent fault; that is being replaced too.
Old Mar 3, 2016 | 04:30 PM
Wilbur06's Avatar
Default Prnds lit all the time
I have the same issue, I bought an 03 TT 180hp knowing the valve body needed attention so I bought the trans go shift kit and installed it. Car shifts great now but takes a second to kick into gear when you go from park to r and to d. I did an ohm test on park neutral switch and everything tested good. I also took apart the center console and checked all the magnets on the tip gate that's all in order as well as all the fuses. The lights on the center console light up when shifting into gear the dash however is not on the same page any help would be greatly appreciated.
Old Mar 3, 2016 | 05:52 PM
PaperToast's Avatar
Banned
this is the allroad section, not the TT
in any case, a vagcom scan will reveal whats going on
Old Mar 8, 2023 | 07:28 PM
Pierson.brice's Avatar
Default What sensor was it
hello, I am having the exact same problem you are. Can you please tell me what sensor had to be replaced?
Old Mar 9, 2023 | 05:26 AM
What sensor had to be replaced?
rbr
16
Apr 6, 2022 11:30 PM
makav3li
Feb 5, 2010 04:13 PM
.Acide// gt2871r'd
Oct 29, 2006 03:21 AM
dagoat_1
May 27, 2004 04:51 PM
audiringpwr
Jan 13, 2004 09:38 AM
