Window regulator?
Just purchased a '01 AR w/88k for $8500. It's just had the front air suspension, air pump and suspension control module replaced. It's also had the torque converter replaced @ 71k.
Not cheap, but I felt it was fair? I welcome comments on that..
Anyhoo.. The most pressing problem is the drivers side window.
Currently if I put the window all the way down and then try to close it I can only raise it 3 inches or so, it will start to struggle and then go back down in "pinch mode".
The only guaranteed way I can raise it is to "walk" it up. I have to go up three inches and then go down an inch, up 4, then down 1. At that point I can usually get it closed.
So.. regulator? Motor?
I'm not getting any creaking, clicking or straining noises associated with it either.
Thanks all!
