Water dripping?
Water dripping?
Just did timing belt,thermostat,water pump,idler, picked up car and flex pipes crumbled ahead of the cat. Stretched a couple sensor wires. Liquid is leaking (dripping) out. Tastes like h20- not oil or gas or antifreeze.What is it? Should I worry more than usual with an allroad? Thanks, ken
Was your A/C running at the time?
Coming from the engine I assume?
Yes.. yes you should
Water dripping
Thanx all. While getting flex pipes repaired my mech checked and said the drip was from climate control running and was normal. Again thanx for the quick responses 😊, ken
AWOT extra 23052
Florida Discussion
07-06-2004 09:05 AM
