Audi Care. Yes or No?
#22
Larry David (07-06-2019)
#23
The lack of a conventional ICE makes me wonder whether Audi Care is a worthwhile addition. I have it for my 2017 S6 and I've only serviced the car three times as I've only driven 8500 miles in 2-1/2 years. With no oil changes, or transmission to speak of, what are your thoughts on purchasing Audi Care for the e-tron, considering we don't yet know what traditional "service" will be on a BEV?
#24
John (aka Daddio) (07-06-2019)
#26
e-tron maintenance contract
#27
Until we know costs from Audi, I would wait to see if it will save money.
#28
Maintenance required to keep warranty intact
Not exactly......Audi DOES require specific maintenance to keep warranty intact, BUT the maintenance does NOT have to be done by Audi.
Found this at https://www.consumer.ftc.gov/article...ne-maintenance
That said, there may be certain situations where a repair may not be covered. For example, if you or your mechanic replaced a belt improperly and your engine is damaged as a result, your manufacturer or dealer may deny responsibility for fixing the engine under the warranty. However, according to the FTC, the manufacturer or dealer must be able to demonstrate that it was the improper belt replacement — rather than some other defect — that caused the damage to your engine. The warranty would still be in effect for other parts of your car.
Do I have to use the dealer for repairs and maintenance to keep my warranty in effect?
No. An independent mechanic, a retail chain shop, or even you yourself can do routine maintenance and repairs on your vehicle. In fact, the Magnuson-Moss Warranty Act, which is enforced by the FTC, makes it illegal for manufacturers or dealers to claim that your warranty is void or to deny coverage under your warranty simply because someone other than the dealer did the work. The manufacturer or dealer can, however, require consumers to use select repair facilities if the repair services are provided to consumers free of charge under the warranty.That said, there may be certain situations where a repair may not be covered. For example, if you or your mechanic replaced a belt improperly and your engine is damaged as a result, your manufacturer or dealer may deny responsibility for fixing the engine under the warranty. However, according to the FTC, the manufacturer or dealer must be able to demonstrate that it was the improper belt replacement — rather than some other defect — that caused the damage to your engine. The warranty would still be in effect for other parts of your car.
#29
Club AutoUnion
There's no reason you have to buy AudiCare right now, you can wait until you hit 10,000 miles and then decide at that time. I bought it at delivery because i had a $100 off coupon, otherwise i would have waited.
#30
Came across this link that appears to be e-tron specific.
https://www.audiusa.com/content/dam/...-8-20-2018.pdf
Even the standard service (every 2 years), mostly checking the box. Changing brake fluid is optional? Are they kidding?
