e-Tron at drive-in movie night
Has anyone done a test how much battery % or range will you use per hour leaving your e-tron running with A/C and FM radio ON while parked? I am planning on watching a movie in one of those drive-in theaters but most of them are long drive into rural places with no fast charging around so good battery management may be a key on those type of trips. Summer days are still hot but the evenings are not that bad and I do not expect high temperatures but in case it gets uncomfortable (or you need to keep annoying bugs out) you may need to run air conditioner for several hours :/ Would that drain your battery much? What is the power drawn by the A/C in Eco Mode anyway? Using recirculated air vs fresh could probably extend the range or running fan only but I guess the A/C should not use that much battery, right?
Follow up winter question: how about running the heat for 5-6 hours without driving the car? Any tests on that?
Tip: Walmart offers free tickets on drive-in movie tours: details https://www.thewalmartdrivein.com/
Guess'n no more than a couple of miles per hour. You can check this by firing up the A/C and radio in the driveway and see the usage. Haven't been to the drive in for more years than I want to admit.
Haven't read anything on the e-Tron, but with Tesla's having camp mode there's a lot of user data on their power consumption. Obviously not a one-to-one comparison, but people report power consumption of anywhere between 1-2.5kw/hour, with the higher ranges being using the heater in cold climates and AC use being on the lower side. For a summer evening drive-in, I feel like you could plan on losing 2kw/hour and have a nice safety buffer.
As far as 5-6 hours, I'm curious if an e-tron would even do that? Would it continue running for an extended time if no one was in the drivers seat?
you can't get it on your Netflix "experience"
e-tronDriver (08-18-2020)
Do you mean the AC will not turn down by itself after an hour when you park your car. Some people had mentioned that the E-tron will turn the AC off after one hour of no movement of the car.
