Garage Door Opener looses signal power/range
I have found that the garage door opener seems to switch to a weaker signal after a few days. I have now reset the garage 3 times. Each time on the day I do the reset and the next day I can open the garage door from down the street then each time on day three it losses power and I have to drive right up to the door for it to function. Any idea what might cause this?
Ever since they switched the transmitter to the mirror instead of the front of the car I've had nothing but trouble with garage doors. I finally managed to get my eTron synced to my door but it's not 100%. It opens and closes the door from inside the garage but will NEVER close it when the car is outside the garage door. What's even stranger is that as i'm driving down the street coming home it will open the door every single time. If I pull the car out on the road when reversing it still won't close the door. Using the remote transmitter inside the car won't work. I have to put the window down and hold the remote outside the window to get it to close. Kind of annoying!
I’ve had mine programmed for over a week and it’s been fine opening and closing EXCEPT in front of the garage directly. I’m looking at putting an extender in to see if that resolves the problem
Mines been working fine the past week. The only annoyance is the GPS feature seems to be hit or miss if it comes up and when it does it only stays on the screen for 2-3 seconds. Hardly enough to react. Common Audi, I drive all the way get up to the Garage door and then at the last second change my mind? Why does this call up go away at all....
Thx I will look for that.
WRT the garage door I have found that it works better if you hold down the icon a bit longer. After the first Haptic tick hold one Mississippi two Mississippi then release for second tick.
Do you have a LED light in your Garage door opener unit? They have been known to block the frequency from the cars command module to the receiver.
Turns out that they make specific globes for Garage Door Openers
https://www.geniecompany.com/garage-...ight-bulb.aspx
Southpondcamp (07-02-2019)
I've had my e-tron two weeks now. As I back out of the garage, I'm finding it takes about 40 sec on start before the opener will work. On return it's more responsive but not 100 per cent. The Genie remote, which is new, works just fine.
