Adapter update
They have worked no problem. I used my first one for exactly two charges in the wild and my second one for maybe eight charges so far. The first one did not fail, but was lost by the hotel valet. They hotel knocked $160 off the room and I ordered another one the same morning from Amazon for delivery to the next hotel. I have found that I have used them far less than anticipated, but I stow it in my charging bag in the frunk and it is simply another piece of necessary EV gear if you are going to road trip.
There are hard-wired EVSEs (notably, many Tesla destination chargers) that can deliver as much as 80 amps of current (80A * 240V = 19.2kW). If you connect the e-tron to such an EVSE, the EVSE will tell the car's charger that it may draw up to 80 amps, and in response the car's onboard charger will draw its maximum 48 amps. As you noted, if you use the 40 amp TeslaTap in this configuration, there could be problems as more current will be passing through the TeslaTap than it is rated for. And there's no way in the e-tron to "turn down" the current it's drawing -- it will always draw the maximum that the EVSE allows (up to 48 amps).
This is why I purchased the 50 amp TelsaTap. While strictly speaking, using the 80% rule for electrical ratings, one should actually be using an adapter rated for ~60 amps, I'm confident that the 50 amp adapter works fine when connected to a >40 amp EVSE. And in fact, I have empirical evidence to support this -- the last long trip I took, I plugged my e-tron into just such a hardwired high-power Tesla destination charger. The dash readout showed 11kW charging rate (full 48 amps) and the (50 amp) TeslaTap stayed cool to the touch for the entire 3 hour charging session.
