Camera View Weirdness
Old Sep 1, 2023 | 09:10 AM
toomanymc's Avatar
Default Camera View Weirdness
New owner of a 2019 with a 10/2019 build date. I searched and didn’t find anything.
My rear view/360 camera only seems to activate about 50 % of the time when I shift into reverse and when it does it takes about 10-15 seconds to render the car animation in the 360 view or sometimes the car animation never renders. When the cameras don’t activate I still get the sensor view, just no camera image.
is there a trick to this or is something funky going on with my particular car. I am the second owner and I purchased at carmax so I have a 4 month warranty on the car. Car has 45k miles and seems well maintained, only real issue is with the rain sensor but I’m pretty sure that is due to a poor job installing a new windshield prior to my purchase that carmax is making right(I think it needs a new gel pack for the sensor)
Old Sep 1, 2023 | 12:04 PM
AudiDan2018's Avatar
You should run your VIN against software recalls on the Audi website. It sounds like your vehicle is missing a very important update that solves this issue and many more glitches.
Old Sep 1, 2023 | 01:52 PM
toomanymc's Avatar
I already checked my VIN and there are no outstanding recalls or service campaigns but I didn’t look at TSB’s. I will check and see if any apply to the camera as I am still under warranty.
Old Sep 1, 2023 | 04:15 PM
skaven81's Avatar
Mine (also a mid-to-late 2019 build) does this as well (but not with the frequency that you describe). I find that it happens most often when I shift into reverse too quickly after powering the car on. I also have no pending TSBs, software is up-to-date as far as I am aware.
Old Sep 1, 2023 | 05:53 PM
toomanymc's Avatar
I was kind of thinking it might have something to do with that. It does seem to happen most often when parallel parking or 3 point turns. One of my theory’s is that it happens if I shift into reverse without making a “full stop”.
When it happens if I shift into D than back to R it works fine or if I push the camera button off than back on.
more I think about it the more your theory fits, they did update the MMI after 2019 to one with more processing power
Old Sep 1, 2023 | 06:18 PM
JNealCox's Avatar
I just got used to it happening on occasion. For me, shifting from R to D and back to R would fix the problem whenever it cropped up.
Old Sep 1, 2023 | 08:06 PM
Brock Tune's Avatar
That makes me wonder if you have in fact received all the updates, because that's a behavior change I very much remember having to adjust to after one of the (I believe) battery updates, where before I could do a pretty casual/quick change into reverse, after the update if I tried that it simply would stay in drive, and I had to change my habits to fully push down on the brake pedal before the vehicle will let me shift into reverse (its something that sticks out to me because I had very much developed a muscle memory of shift into reverse a certain way, it took some time for me to adjust, with post-software update definitely requiring a full stop).
Edit - just because I remembered I had posted about it at the time, I can see this change happened with the 93M3 update; https://www.audiworld.com/forums/aud...#post25680107; and now that I think about it I did used to get either the sensor view or even sometimes just a black screen when shifting into reverse, not quite 50% of the time but with some frequency, but I can't remember the last time that's happened to me so maybe this (or some other) update did address that too
Jack D
Audi A3 / S3 / RS 3
Mar 1, 2022 11:57 AM
Moonlightblue
Q5/SQ5 MKI (8R) Discussion
Mar 12, 2019 09:01 AM
keclear
Q7 MKII Discussion
Mar 8, 2017 04:07 AM
adminisTerTurbo
Audi Original "S" Cars
Apr 26, 2008 11:08 AM
danham
Audi A3 / S3 / RS 3
Sep 1, 2005 04:46 AM
