Charging location setting
Old Sep 4, 2022 | 06:15 AM
T-Rex06's Avatar
Default Charging location setting
Hi everyone, I finally got the e-tron S. I've set up the charge location on Audi app and set it to charge between 10pm to 5am. However, when I plug in the charger, it will start charging even though it's outside the preferred time slot. Am I missing a setting? I do get a notification on the MMI saying charging location activated whenever I get home though. Any insights will be appreciated.
Old Sep 4, 2022 | 06:26 AM
rdgrimes's Avatar
If the "minimum" setting is on, it will charge right away till it reaches minimum SOC.
Old Sep 4, 2022 | 07:03 AM
T-Rex06's Avatar
I don't see the "minimum" setting on the app. The "Immediate charge to 25%" function is turned off. I'll check the MMI in a bit. Thanks for the quick reply.
Old Sep 4, 2022 | 07:08 AM
weth's Avatar
It has been a while since I used this, as I use the time function on the ChargePoint now, but I recall I had to push something every time I turned off the car at home to activate the delay. Came up on the MMI when you turned off the car like being able to keep HVAC on when turning off car.
Old Sep 4, 2022 | 07:12 AM
T-Rex06's Avatar
Thanks. I did see a notification about charge location pop up on the MMI whenever I get back home. I didn't know that I have to enable it. Kind of defeat the whole purpose of having a preset lol.
Old Sep 4, 2022 | 11:02 AM
JNealCox's Avatar
I don't use the Location option, but use the timer a lot. On the Shutdown screen, I will see a list of timers I have "enabled" for use. To activate one of them, I have to press the icon to the left of that timer until a red bar appears at the top.
Old Sep 4, 2022 | 11:30 AM
skaven81's Avatar
This is my #1 complaint about how Audi implemented the charging interface. In order to get the delayed/timer based charging, you have to configure a charge timer in addition to the "saved location" which limits chargin to a specific time window. It's incredibly uninutitive and I can't fathom how it made it out of UAT. But anyhow, here's the process:
  1. Set up your charger location setting, where you specify a location, charge time window, and desired target SoC percentage. Note that the target SoC percentage is overridden any time you adjust it from the main "charging" interface in the UI.
  2. Create a new charging timer. You need to set this to the time you are likely to leave in the morning (and thus want to ensure that the car is charged up by this time).
  3. Get into the car (yes, you have to actually get into the car). Close the door (this won't work if the door is open). Power on the car (yep). Wait for a bit so the MMI boots up.
  4. Turn off the car. On the MMI you'll see a "goodbye" splash screen with some options. You should see the charging timer you just set up, visible with a big clock button to the left. Tap the clock and you get a red line over it, indicating that the charging timer is now active.
  5. Exit the vehicle
  6. Plug your charger in. It will initialize but then stop and give you a flashing (instead of pulsing) green light, indicating that it's waiting for the charge timer.
  7. The car will now strive to have your car charged by the time the departure timer is set, and since you have a charge location defined, it will prefer to charge during that window.
In practice, once you have this set up, it becomes somewhat reflexive:
  1. Return from driving around for the day, and pull into the garage.
  2. Power off the car but do not exit yet.
  3. Tap the clock button on the MMI to activate the charge timer
  4. Exit the vehicle
  5. Plug in the charger
It is also possible to switch charging over to timer mode after it has started. This process goes:
  1. Plug the charger in. Car starts charging immediately (pulsing green light)
  2. Open the myAudi app, go to "charging"
  3. Tap "switch to timer mode"
  4. Assuming the app is able to communicate with the car (which I only have about 20% success with), the car will stop charging and you get the blinking green light indicating it's waiting for the charge timer.
Old Sep 4, 2022 | 01:39 PM
JNealCox's Avatar
Great summary! I think I could even do this now.
One comment regarding the first item "2", be aware that, if you use the MyAudi app to set up a timer, when you turn the slider button to "on" you are NOT activating the timer. You are only "enabling" it so that it will show up on your Shutdown splash screen, making it available for you to "activate". It's on the screen in the car where you have to activate it by pressing the icon. If you have a bunch of timers set up, using the "enabling" sliders to turn some on and off helps reduce the clutter on the Shutdown screen.
 Pouria Savadkouei
 Michael S. Palmer
Old Sep 4, 2022 | 04:58 PM
T-Rex06's Avatar
Thanks skaven and Neal. No wonder it didn't work for me. I was under the impression that once you set the location, the car is smart enough to follow the setting. The fact that it even shows on MMI that I've reached the "saved location" makes me think I'm good to go.
Old Sep 6, 2022 | 06:52 AM
yeamac's Avatar
Institutionalized Member
I agree it is very unintuitive the way the "preferred charging time" works. It is basically useless and the only thing the e-tron does is either charge immediately, or with the timer.
I have preferred home electric rates from 11pm-7am for owning an EV, so set my preferred charging time from 11pm-7am at my home location. I set my timer to be ready by 6:55 am., which, needs to be activated when I want to use it. There has been a couple of times I either forgot to activate the timer, or had the timer set, had to run out in the evening unexpected, return home, plug in (forgot to reactivate timer so the red line shows again), and then get a notification at 10:40pm that my e-tron has finished charging. Argh! What about my "preferred charging" not starting until 11pm? Why did it start charging at 8pm when a few more hours would have been 11pm, my "preferred charging period?" I don't think the "preferred charging time" does anything at all. It sure doesn't delay charging when you plug in. The timer is required for any delay in charging.
