Charging Plan
Old Jun 23, 2019 | 03:07 PM
hrc1079's Avatar
Default Charging Plan
Sorry if this is posted somewhere but searching through I couldn't seem to find anything. Can you set the car to charge from a certain time only? Eg. I want to start charging at 11pm when it's the cheapest rate but it doesn't appear you can do this. The app just asks when you're leaving and I thought I found a schedule in the MMI but when plugged in at 7pm it started charging immediately.
Old Jun 23, 2019 | 03:29 PM
2KA6_2.7T's Avatar
Our e-tron doesn't support setting a start charging time, only support charge to set target SoC by leave time.
There are two ways to use the features
WIthout the app, once you are parked, Press Start/Stop to turn off the car. and on the MMI. click on the schedule to make sure it turn "RED" . if the schedule doesn't appear you will have to go enable those schedules ( Toggle the appropriate ones to ON)
With the app. assuming the charging cable is plugged in and Already charging. in the App. Click Charging Planning -> Timer -> set and toggle one or more to ON -> Send to Vehicle. Then Enable Timer Mode, in the previous screen.
With a JuiceBox Pro, you can set the start charing time ; as well as smart feature where eMotoWerks know the best time to charge, base on real-time supply and demand data from the Power Plants
Old Jun 23, 2019 | 04:39 PM
hrc1079's Avatar
Thanks for the clarification. I was trying to avoid buying the Jb Pro but I’m not a fan of the Audi charger.
a) they don’t provide a mounting bracket
b) it always turns on at 50% even though it’s plugged into a 240v 50amp outlet
c) the myAudi app isn’t the friendliest of apps and very limited on what you can do
Looks like I’ll be off to buy the Jb. Annoyingly, the landlord has stated if I mount anything to the wall in the garage then it’s considered part of the dwelling and must remain when I leave so I’m effectively giving him a house that is now EV ready.l which is why I was reluctant to buy the Jb. The Audi charger is just on the floor at the moment.
Old Jun 23, 2019 | 05:17 PM
2KA6_2.7T's Avatar
The JuiceBox comes with a small metal bracket that you mount on the wall; the box can a) just hang there or b) an additional screw to hold it in place.
So technically only that small approx. 6 in by 1 in piece of metal is mounted on the wall :-)
see here https://docs.juice.net/Residential/US/Installation.html
Old Jun 24, 2019 | 06:20 AM
e-tronDriver's Avatar
Club AutoUnion
This sounds like bull$hit. I'd double check the language in your lease. If what you're saying is true, it basically allows the landlord to steal your JuiceBox. Either way, i don't know how he'd enforce that if you take it with you when you leave. And as previously posted, you could just leave the bracket since that's the only part attached to the house.
Old Jun 24, 2019 | 07:50 PM
Southpondcamp's Avatar
My electrician mounted my juice box to a plywood panel that was affixed to the garage wall....leave the plywood .. not the juice box?? 😁
Old Jun 24, 2019 | 09:02 PM
hrc1079's Avatar
Lol! To be fair, I’m grateful that the landlord let me install the power outlet even though it was at my expense he could’ve easily said no. I’m thinking I’ll just leave the bracket behind and treat it as a hook if he ever pushes upon it. At the end of the day he got a free charging outlet plug installed.
purdueATX
Q7 MKII Discussion
Dec 12, 2024 05:14 AM
CRAMAZING
A6 (C7 Platform) Discussion
Jun 12, 2012 06:39 AM
1993audi90
Sep 7, 2011 09:07 PM
BigNewf
Q5/SQ5 MKI (8R) Discussion
Mar 12, 2010 07:27 PM
ScottAW
Jun 21, 2001 09:09 PM
