e-tron Error Log Help?
The log shows a lot of intermittent communication failures between various control modules in the car, e.g. on Feb 14th-15th and March 17th 2024. If the car was in the workshop these dates, it could be caused by modules being removed during debugging. If they rather happened under normal usage conditions, it points to a bad connection somewhere or software glitches (which is not that uncommon)
My main takeaway from the log is that none of the errors suggest any external influence causing the failures (thus no user induced error). Audi might also argue that this log is perfectly normal, and does not show any noteworthy issue with your car (at the time the log was collected).
