Performance drop going from Efficiency to Auto to Efficiency
I thought I was losing it but I'm pretty sure this is not my mind playing tricks.
Cold start straight into efficiency = all god
If I then go to Auto, Dynamic or Comfort and then switch back to efficiency, it feels very sluggish. You are literally having to mash the pedal down to move to the point overtaking can feel a bit dangerous.
Do you find the same "issue"?
Again to work out whether this was just going from a good setting to a low setting, I did a quick cycle from Eff to Auto to Eff within a few seconds without actually driving and I got the same feeling of performance drop vs if I just started up in Eff mode.
Very strange!
Thanks all
Very strange!
Thanks all
1) put climate control system in ECO mode
2) allow air suspension to lowest setting (even more than dynamic!) at highway speeds
3) put steering response in a mid response range
4) change acceleration response to be subdued to save energy on acceleration and change the shift indicator to "E" in the dash
Changing to D or S manually, or stopping and then restarting the e-tron will not default the Enron back to efficiency mode acceleration response. The climate control, air suspension and steering response do stay in the efficiency mode, but the acceleration response does not.
If you want to go back to the efficiency acceleration response with the E in the dash, you must go out of Efficiency mode and then back in.
Some will say the best dynamic mode is Efficiency mode with shift in S mode allowing the lowest suspension stance than even Dynamic mode gives.
Personally, I use the efficiency mode when on a road trip and only once I get on an Interstate. You can always kick down to the click to get an emergency acceleration if needed. It does seem to make a difference in the efficiency numbers over long trips.
After reading this, I suddenly had a thought that the dash displayed an E instead of a D or S but this was not the case.
I see the Efficiency text and its green but in the middle, it still displays D or S.
ie: I set to Eff mode, park and switch off.
Next day, I start and drive in the Eff mode I left it in last night. All good and performance is fine. AC is in eco mode too.
At this point if I change to Comfort, Auto, Dynamic, Offroad and then switch back to Eff mode, its as @thebishman mentions - far too slow to accelerate from a dead stop. Something not an issue when simply starting from Eff mode and not changing out of it.
Ironically today I left it in Auto and got 2.4 miles/kw instead of the 2.0/2.1 I have been getting for the same trip/weather conditions.
For some reason, efficiency mode acceleration mode only is in effect when you first go into efficiency mode program, even though the other efficiency mode items do "stick", the acceleration part does not. If you stop and restart the e-tron, it defaults back to D and you are not in efficiency acceleration mode. By design efficiency mode acceleration is diminished.
As I read it, a "PROGRAM" describes "throttle" behavior (ie, is the accelerator pedal and battery configured to maximize efficiency (E), or to let you warp down the road (S), or to just comfortably drive (D). Of course, your also have "R" for going backwards. The "Throttle Programs", to me, are as close as you will get to having "GEARS". In contrast, a "MODE", selected through Drive Select, describes a combination of vehicle traits--suspension, throttle, steering, etc.---not just throttling behavior.
If you use Drive Select to pick the "Efficiency Mode", the car will automatically select the "Efficiency Program" (your sluggish driving). If you turn the car off and back on, the car keeps all the the previous "Efficiency Mode" settings (eg, low suspension height), BUT puts the car into the "D" Throttle PROGRAM (your acceptable driving). So, you can, A) use Drive Select to pick Efficiency and you get the most efficient group of settings (Including the EFFICIENCY Throttle PROGRAM);or, B) use Drive Select to select Efficiency MODE, turn the car off and on, and you will get "Not Quite As Efficient Efficiency Mode", since the car has defaulted to the DRIVE Throttle PROGRAM.
How's that for a murky mess?
So the difference (now obvious) is the lack of 'E' displaying for me at ANY point. When it is in Efficiency mode via drive-select, it shows D including when I switch to another and go back to Efficiency (when I get the poor performance) so I never actually know it's in the Efficiency mode for "throttle behaviour".
I'll get this seen to in a couple of weeks when I visit the dealer for other outstanding warranty items as it does indeed sound like a software update is required.
Thank you again - clears up a lot and I have also picked up a new word to add to my vocabulary - nomenclature
