Puzzling Charge/Range Issue
Because we've been making a spate of longer-range trips recently, I set my last four or five sessions in a row to charge to 100%. Predicted range has been around 210 miles at this level and depending on how I drive I've been able to beat this by a bit. On our final trip I also charged (for the first time!) at a 150kv EA DC charger to top up to 85% before returning home.
Last night I programmed the car once more to charge the battery overnight at home to its normal 80% level. But this morning, to my surprise, the predicted range was shown as only 150 miles.
Is this a calculation glitch that will sort itself out once the car is driven and charged again a few times to 80% or is it the first sign of a problem? I know Audi says that charging to 100% will eventually reduce battery performance but I can't believe a handful of full charges will case this.
Has anyone had a similar experience? Any thoughts?
(FWIW I've not yet had the software update done which increases range.)
Just drive it normally. You should be able to equal your normal milage. And you should be able to HAMMER on the DC charging a lot over the life of the car.
The only thing that would cause problems is if you have a bad cell / BMS. There are reports of this happening but the symptoms are now understood quite well: your actual range will continually reduce and more importantly the charge carrying ability of the battery will decrease. If you don't see either of those issues, it's just the GOM and it will reset...
It's a symbolic number regardless, meaningless to most drivers in real life, day-to-day driving. Your current efficiency and state of charge are all that matter on the daily unless you're a super heavy commuter.
