Range Meter?
Old Apr 22, 2021 | 03:28 PM
SignDoc's Avatar
Default Range Meter?
I traded in my 15 month old P+ for a 2021 Prestige. When I got in my 2019 e-tron and turned on the ignition, the range meter obviously displays and it would match the range number from when it was parked from my previous journey when I turned the ignition off. In my 2021 e-tron, the range meter acts differently when I switch the ignition on. It displays a range lower than when I turned the ignition off from my previous journey, but after a second or two the range starts to automatically increase upward (by ones) an ultimately reaches the range from when I last turned off the ignition. This morning I arrived at work with 178 miles showing. When I got in to leave tonight, the range showed 176 when I turned on the ignition then it started to go up and actually went to 179, one mile past the 178. Every setting on the vehicle is untouched and the same. I never once had this happen in my 2019, has anyone else experienced this?
Old Apr 23, 2021 | 02:11 PM
BimmerCaddyAudi's Avatar
They may have changed it to more aggressively include other power draws such as initial cabin/battery heating and cooling. Initial start up may draw more power to perform these things.
My 2020 seems to do the same when it comes to changes in the range meter.
Stolier Dumitru
Q7 MK 1 Discussion
Sep 5, 2020 07:11 AM
BlackMCoupe
Apr 13, 2007 11:02 AM
Mr.88-80Q
Nov 9, 2005 10:13 AM
thtguy
Sep 21, 2002 07:48 PM
