Second key buttons programming?
Old Feb 5, 2024 | 06:19 AM
A4 Phil's Avatar
Default Second key buttons programming?
I have only ever used my primary glossy key fob. This past weekend I tried using my dull second set. I went outside and nothing. It would not open the doors. If I opened with my phone, the car did start when I placed the key on the key pad.
I changed the battery and now I get nothing. No open/close and it will not start.
How do I re synch my second key fob with my car?
Old Feb 5, 2024 | 07:37 AM
orbit0353's Avatar
I think you never need to re-sync the keys, unless you have had the comfort access module replaced/serviced (In that case, the workshop should ask for both keys before doing the job).
Does the small red LED on the non-functioning key light up when you press the buttons? If not, the battery might not be fully inserted. BTDT, it's a bit fiddly despite seemingly looking trivial.
Old Feb 5, 2024 | 10:22 AM
A4 Phil's Avatar
I'll check. I certainly have not seen a red light on my keys.
Old Feb 5, 2024 | 10:42 AM
Ryanthegreat1's Avatar
There is a red light between the unlock button and the small Audi logo.
It shines through the plastic, no indication of a light there just by looking at the surface.
Old Feb 6, 2024 | 03:25 AM
A4 Phil's Avatar
Update:
In that weird Audi way, the secondary key fob just started working eventually. I simply cannot say what caused it to work. A button sequence or being in my pocket while using the primary FOB in the car. It just went from zero actions to fully usable and I have no idea why.
CaptainQuacks
Audi allroad
Oct 12, 2019 01:28 PM
mayfair86
Aug 14, 2018 04:47 AM
Jose Arriaga Jr.
Nov 24, 2017 08:08 AM
mrandrewjames
Nov 17, 2017 12:28 PM
Boostedws6
A7
May 5, 2013 04:05 AM
