Weekly Calendar Driven Climate Timer
It's apparently located under "Car menu > Charging & efficiency > Charging. A charging target for the high-voltage battery of between 50 % and 100 % can be set for the charging procedure. The timer settings can be accessed by swiping the battery level display to the left. Five different timers can be programmed. This involves selecting a day or days and setting the departure time. Air conditioning of the vehicle interior can also be activated in the timer function."
How does one set the temperature of the climate control? Will it simply use the last known temperature and seat warmer settings?
According to the Bjorn Nyland video, e-tron is one of the few BEVs which perform two-parallel power draws (one for the battery, other for climate control) during DC charging. I would hope that this applies to AC charging as well. This is difficult to determine since, during the AC charging, EVSE is already delivering max power.
