Cabin Air/Pollen Filter
So I'm trying to find the cabin air filter and I think Im in the right area. Some of the old threads and the Q&A have expired pictures so I thought this might help others to since its time to start running the AC for the summer.
I read that you have to remove the wiper arms and get some more space to work. The green items on the picture will need to come out I assume.
My question is... is the filter in the area where I circled the nut heads in red...or....is it behind that further back. Can I tell if I even have a filter from this picture or do I need to dig further to see that. Thanks for the help.
Once they are out, pull the 3 bolts and the cover, then the old filter if there's one in there- they didn't come with a filter from the factory, and most cars don't have them.
Make sure you vacuum out that area thoroughly- I usually pull the glove box so I can get at the inside also.
Thanks UrScubed....so Im on the right track.
I guess I stopped here b/c I'm somewhat worried that if I mess with the wiper arms by removing them I will never get them back again correctly, and that they might start slipping on the post the next time it rains. Might be a task that requires a chalk mark so you can see where they were when you putt them back.
Seems like I had a car in the past I did this on and they would never get tight again. Dont want the wipers slipping when I'm blazzing down the hwy in a light rain.
** I also remember a bunch of dried leaves up in the vent above the ECU when I took it out last year to put the Hoppen chips in. Makes me think I have no filter for those leaves to get there.
Nice...when I get a chance to finish up I'll try and post a few more pics. I'm not sure I'm going to put a filter in there, I just dont want an old dirty one in there dragging down my fan action. I also want to vacuum out all the stuff in there and get it cleaned out at least.
<http://www.autohausaz.com/> or <www.germanautoparts.com> carry the correct 4A1 820 367 filter. There are many inaccurate online catalogs that list a Bosch carbon impregnated filter but it is too thick and not the correct dimensions for the S6. For those just reading, the UrS4 has no filter holder. It is a 348X213X20 filter and despite the difficulty accessing it, I think it is a help in keeping the a/c clean.
The wiper arms have a spring washer under the nut to keep things tight - don't lose it.
I got the Mann filter
fit like a charm on a 1995.5
and Yes,those directions are correct.
MANN-FILTER CU 3562
UPC/EAN Code 4011558247409
web site
http://www.mann-hummel.com/mf_prodka...obackToPage=11
MANN-FILTER CU 3562
web site
So I got in there today and finished the job. There was NO filter in there so I cleaned it out real well with a vacuum with creative attachments to get in there. I left mine w/o a filter. I think the suggestions to get into it from the passenger foot-well would be a good idea to clean it out. I vacuumed out the entire area under the main cowel cover while I was in there. Also make sure you set the rear edge and the groove on the filter top before you put the 3 bolts back. The back edge locks in first.
You guys were correct about taking the wipers off, it wasnt to difficult and b/c there are little grooves in there I dont think they will slip later. Only 1 of my wipers had a spring washer...
The upper rain deflector, that has 4 allen bolts, has a screen built into it and mine is deteriorating badly(pic included). It doesnt look like you could replace just the screen unless you re-caulk a new one into it somehow, if you could find some black screen.
Thanks for all the great suggestions and hopefully this will help some others too. Cheers
DesmoTesta
06-19-2006 08:10 AM
nothing2007
01-19-2005 06:14 AM
