dash beep driving me crazy-long
Here is the deal....
The 2"x2" area that shows the "OK" symbol and radio status is not working or at least is not lit. On rare occasions, it will show my radio station etc..but I have not even seen this in a while.
For the past several weeks it has no lights and it beeps fairly often. Sometimes once a minute for maybe 5-8 minutes and then it will not beep again. I have shown a flashlight on the dash and I can see what looks like a bomb with an X thru it. The owners manual says this is a warning for headlight or tail light. However, both are fine. Hmmmmmmmmm.
To add to the sage, the other day I disconnected the battery an the "OK" sign showed on the dash for the first time in a long while, when I reconnected the battery and started car for the first time. After the first start, it is back to its old ways.
Any suggestions appreciated.
Mike 93S4 103k
Mike 93S4 103k
You can get them at any audi dealer for around $5 each, or online for more like a buck each. There are two: one has a yellow cover and one has a red cover. You can probably transfer these bulb covers to the new lamps. One bulb is normally used when the headlights are on and the other when they are off.
Once the display is working again you can move on to fixing whatever is causing the alert. Obviously if it's a false bulb out reading it's not a critical issue. But other alerts (low brake fluid, low coolant, etc.) are more urgent...
Also, if you pull (or is it push?) the left hand button on the custer (the dimmer switch) the autocheck will go through a diagnostic procedure and show you all of the icons.
AudiSpaulding
09-27-2008 06:48 PM
BluHeaven
12
06-11-2004 04:10 AM
zamicus
02-26-2004 05:23 AM
Merkin
11-15-2003 01:28 AM
