fuel pressure
yikes! at idle i'm at 39psi and at 60psi on full boost. what should i look for?!
fuel pump is gonna go. period. or maybe i'll just check the voltage at the fuel pump and see if its getting 13 volts.
I was getting 28 psi boost from the "370" software so I needed ...
58 + 28 = 86 psi minimum. The pump was only putting out 83 psi under simulated conditions (engine off but with 28 psi applied to the 4 Bar pressure regulator). As a result, I was leaning out under WOT boost. Relaying the pump to the battery helped.
Use search for the procedure/write-up about last August 8th (2004).
Dave F.
Dave F.
Link to the auxillary fuel pump relay retrofit procedure.
<ul><li><a href="https://forums.audiworld.com/s4s6/msgs/31970.phtml">https://forums.audiworld.com/s4s6/msgs/31970.phtml</a</li></ul>
thanks. 43.5psi.
bai omule, da-m un email. ma disper!! ) ai primit ultimul email dela mine?!
ce crez de asta? ar fi pompa de vina? ma gindeam sa incerc alt chip dar nu cred ca chip-ul e de vina. hmmm am schimbat si filtru de benzina, injectoarele, burjiile, si nu mai stiu cite alte. trebuie sa controlez ce volt primesc la pompa. bine, trimite-m si mie un semn de viata. ciao.
