instructions for s6 steering wheel converision, BUT...
I'm looking for the conversion to do it without having to cut and glue the clock spring. I have all the necessary s6 stalk, etc. I'm just looking how to swap the wires, etc. Please let me know if you have any info. I know Europrice had the kit and instructions in the past.
Thanks in advance!
Thanks in advance!
Good luck. Swapping the pins, etc. from the UrS4 to a UrS6 stalk is a LOT of work. Plus you need the NLA spacer that was once in the Europrice kit. I have no info about that.
The clockspring signal cancellation ring modification that Steve Young did based on my "Method 3" will work fine if done as shown and glued with a proper epoxy.
I don't think it'd be hard at all to do. I have the spacer too (from genuinevwaudiparts.com). The $40 I spent on it is worth it if I don't have to hack the conversion together with glue.
Thanks
Is this helpful to you at all, check it out anyways.
http://www.s-cars.org/postnuke/modul...article&sid=67
That is the old method. Follow the link inside from the FAQ to the new method, Method 3, developed by me and first implemented by Steve Young:
https://www.audiworld.com/forums/sho...php?p=18915750
mroberte
07-14-2021 06:23 AM
TimD
05-14-2008 03:36 PM
boogs
10-22-2005 06:04 AM
